Giriş
This guide will assist you in replacing the HP LCD Screen. You will need to replace the screen if your screen displays black and white lines over your homepage.
Neye ihtiyacın var
Open the laptop so you can see the screen.
Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
Bir başkası bu kılavuzu tamamladı.
