Ana içeriğe geç
HP 17-x027ds LCD Screen Replacement
Neye ihtiyacın var
  1. HP 17-x027ds LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. HP 17-x027ds LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. HP 17-x027ds LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Open the laptop so you can see the screen.
    • Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
    • Remove the bezel by starting on the sides of the screen and lastly removing the top outlining.
    • When removing the bezel, be cautious not to use too much force or else you will damage the screen. Apply just enough pressure to create a gap between the bezel and screen.
  2. HP 17-x027ds LCD Screen Replacement: adım 2, 3 resimden 1. HP 17-x027ds LCD Screen Replacement: adım 2, 3 resimden 2. HP 17-x027ds LCD Screen Replacement: adım 2, 3 resimden 3.
    • Lift the bezel off the screen to see the outlines of the LCD screen.
    • Remove the four black 3mm screws in each corner of the screen with a JIS #1 screwdriver.
    • Remove the two silver 4mm screws located at the top of the screen with a JIS #1 screwdriver.
  3. HP 17-x027ds LCD Screen Replacement: adım 3, 2 resimden 1. HP 17-x027ds LCD Screen Replacement: adım 3, 2 resimden 2.
    • Remove the LCD screen and place it on the keyboard.
    • Disconnect the video cable to completely detach the LCD screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bill Hoang
452 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 713
