Ana içeriğe geç
HP 17-x061nr RAM Replacement
Neye ihtiyacın var
    1. HP 17-x061nr RAM Replacement, HP 17-x061nr  Disassembly: adım 1, 3 resimden 1. HP 17-x061nr RAM Replacement, HP 17-x061nr  Disassembly: adım 1, 3 resimden 2. HP 17-x061nr RAM Replacement, HP 17-x061nr  Disassembly: adım 1, 3 resimden 3.
      • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
      FixBot'a Sor
      Yorum Ekle
    2. HP 17-x061nr RAM Replacement: adım 2, 2 resimden 1. HP 17-x061nr RAM Replacement: adım 2, 2 resimden 2.
      • Peel back the rubber footrests located next to the battery, on the left and right sides.
      • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. HP 17-x061nr RAM Replacement: adım 3, 1 resimden 1.
      • Slide the optical drive out and away from the laptop.
      FixBot'a Sor
      Yorum Ekle
    4. HP 17-x061nr RAM Replacement: adım 4, 3 resimden 1. HP 17-x061nr RAM Replacement: adım 4, 3 resimden 2. HP 17-x061nr RAM Replacement: adım 4, 3 resimden 3.
      • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
      • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
      • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
      FixBot'a Sor
      Yorum Ekle
    1. HP 17-x061nr RAM Replacement, RAM: adım 5, 1 resimden 1.
      • Locate the RAM module.
      • Locate the metal clips on either side of the RAM module.
      FixBot'a Sor
      Yorum Ekle
    2. HP 17-x061nr RAM Replacement: adım 6, 1 resimden 1.
      • Using your finger, pry the metal clip from both sides of the RAM module and the module will "pop" up.
      FixBot'a Sor
      Yorum Ekle
    3. HP 17-x061nr RAM Replacement: adım 7, 1 resimden 1.
      • Remove and replace the RAM module.
      • Be sure to keep the replacement within the package until you are ready to place it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Amaury Ferrer
235 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 1,160
