Ana içeriğe geç
HP 17-x116dx Space bar key Replacement
Neye ihtiyacın var
  1. HP 17-x116dx Space bar key Replacement, Space Bar Key: adım 1, 1 resimden 1.
    • Locate the spacebar key.
  2. HP 17-x116dx Space bar key Replacement: adım 2, 1 resimden 1.
    • At the edge of the space bay key use a spudger to help with the removal.
  3. HP 17-x116dx Space bar key Replacement: adım 3, 1 resimden 1.
    • Slide the spudger under the spacebar key.
  4. HP 17-x116dx Space bar key Replacement: adım 4, 1 resimden 1.
    • The left side of the spacebar key will start lifting up. At this point you can remove the spacebar key.
  5. HP 17-x116dx Space bar key Replacement: adım 5, 1 resimden 1.
    • During this point you can carefully take off the spacebar key.
  6. HP 17-x116dx Space bar key Replacement: adım 6, 1 resimden 1.
    • you will notice a metal bars along the rim these metal bars is what connects the bottom surface together.
  7. HP 17-x116dx Space bar key Replacement: adım 7, 1 resimden 1.
    • Dust off any dirt that could be under there.
  8. HP 17-x116dx Space bar key Replacement: adım 8, 1 resimden 1.
    • The lower edge of the keyboard has two plastic notches on either side.
  9. HP 17-x116dx Space bar key Replacement: adım 9, 1 resimden 1.
    • slide the bracket into the space below the spacebar to carefully place it back.
  10. HP 17-x116dx Space bar key Replacement: adım 10, 1 resimden 1.
    • The Spacebar key will be working once you can press down and it will type a space.
Sonuç
Liliana Chuc
281 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 963
