Ana içeriğe geç
HP 17-x173dx Optical Disk Drive Replacement
Neye ihtiyacın var
  1. HP 17-x173dx Optical Disk Drive Replacement, Optical Disk Drive: adım 1, 1 resimden 1.
    • Start by placing the laptop with its bottom facing up.
    • Using the Phillips #0 screwdriver, remove the single 7 mm screw that holds the disk drive in place.
  2. HP 17-x173dx Optical Disk Drive Replacement: adım 2, 2 resimden 1. HP 17-x173dx Optical Disk Drive Replacement: adım 2, 2 resimden 2.
    • Use a spudger or thin item to apply outward pressure between the disk drive opening and the device to remove the optical disk drive. You may be able to remove it using your fingernail.
Sonuç
Insert new optical drive. To reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 226
