Ana içeriğe geç
HP 17-x173dx RAM Replacement
Neye ihtiyacın var
  1. HP 17-x173dx RAM Replacement, Battery: adım 1, 2 resimden 1. HP 17-x173dx RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Begin by sliding the left tab to the unlock position
    FixBot'a Sor
    Yorum Ekle
  2. HP 17-x173dx RAM Replacement: adım 2, 1 resimden 1.
    • Push each of the two tabs in the direction specified by the picture.
    FixBot'a Sor
    Yorum Ekle
  3. HP 17-x173dx RAM Replacement: adım 3, 3 resimden 1. HP 17-x173dx RAM Replacement: adım 3, 3 resimden 2. HP 17-x173dx RAM Replacement: adım 3, 3 resimden 3.
    • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
    FixBot'a Sor
    Yorum Ekle
  4. HP 17-x173dx RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove fourteen 7 mm screws on the back of the device (two will be underneath where the battery was).
    FixBot'a Sor
    Yorum Ekle
  5. HP 17-x173dx RAM Replacement: adım 5, 3 resimden 1. HP 17-x173dx RAM Replacement: adım 5, 3 resimden 2. HP 17-x173dx RAM Replacement: adım 5, 3 resimden 3.
    • Remove the Optical Disk Drive.
    • Use the spudger to lift the plastic backing, starting from the back right side, near the vent.
    • Remove the back of the device by continuing to lift the plastic around the entire perimeter of the device.
    FixBot'a Sor
    Yorum Ekle
  6. HP 17-x173dx RAM Replacement: adım 6, 3 resimden 1. HP 17-x173dx RAM Replacement: adım 6, 3 resimden 2. HP 17-x173dx RAM Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingernails to carefully pry the two metal retention clips out and away from the ram casing.
    • Then gently bend the plastic retainers away to free the ram stick.
    FixBot'a Sor
    Yorum Ekle
  7. HP 17-x173dx RAM Replacement: adım 7, 2 resimden 1. HP 17-x173dx RAM Replacement: adım 7, 2 resimden 2.
    • Lift the RAM stick away from the motherboard and remove it from the device.
    • Repeat this step for any extra sticks of RAM.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Install your replacement RAM and reassemble your device by following these instructions in reverse order.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,237
