Ana içeriğe geç
HP 2000 - 2D22DX Hard Drive Replacement
Neye ihtiyacın var
  1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
    FixBot'a Sor
    Yorum Ekle
  2. HP 2000 - 2D22DX Hard Drive Replacement: adım 2, 2 resimden 1. HP 2000 - 2D22DX Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
    FixBot'a Sor
    Yorum Ekle
  3. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Loosen the Phillips #00 screw securing the RAM compartment cover.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
    FixBot'a Sor
    Yorum Ekle
  4. HP 2000 - 2D22DX Hard Drive Replacement: adım 4, 2 resimden 1. HP 2000 - 2D22DX Hard Drive Replacement: adım 4, 2 resimden 2.
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
    FixBot'a Sor
    Yorum Ekle
  5. HP 2000 - 2D22DX Hard Drive Replacement: adım 5, 3 resimden 1. HP 2000 - 2D22DX Hard Drive Replacement: adım 5, 3 resimden 2. HP 2000 - 2D22DX Hard Drive Replacement: adım 5, 3 resimden 3.
    • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
    • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
    • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
    FixBot'a Sor
    Yorum Ekle
  6. HP 2000 - 2D22DX Hard Drive Replacement: adım 6, 3 resimden 1. HP 2000 - 2D22DX Hard Drive Replacement: adım 6, 3 resimden 2. HP 2000 - 2D22DX Hard Drive Replacement: adım 6, 3 resimden 3.
    • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
    FixBot'a Sor
    Yorum Ekle
  7. HP 2000 - 2D22DX Hard Drive Replacement: adım 7, 3 resimden 1. HP 2000 - 2D22DX Hard Drive Replacement: adım 7, 3 resimden 2. HP 2000 - 2D22DX Hard Drive Replacement: adım 7, 3 resimden 3.
    • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
    • Lift the hard drive out and away from its socket in the plastic chassis.
    FixBot'a Sor
    Yorum Ekle
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Conor Most
2.778 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G40
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 63
Her zaman: 15,714
