Giriş
This guide will illustrate how to correctly remove and replace the optical drive of the HP 2000 - 2D22DX laptop. Partial disassembly of the laptop is required to access the drive.
Neye ihtiyacın var
Flip the device over and locate the battery compartment.
Slide the battery release latch to the left until the battery is detached from its slot.
A distinguishable pop will be heard when the battery is fully released.
Locate the Phillips-head screw on the left side of the hard drive recess, indicated by a red circle.
Use a #00 Phillips head screwdriver to remove the small screw. Consider using a magnetized screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
