Ana içeriğe geç
HP 2000 - 2D22DX RAM Replacement
Neye ihtiyacın var
  1. HP 2000 - 2D22DX RAM Replacement, Battery: adım 1, 2 resimden 1. HP 2000 - 2D22DX RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
    FixBot'a Sor
    Yorum Ekle
  2. HP 2000 - 2D22DX RAM Replacement: adım 2, 2 resimden 1. HP 2000 - 2D22DX RAM Replacement: adım 2, 2 resimden 2.
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
    FixBot'a Sor
    Yorum Ekle
  3. HP 2000 - 2D22DX RAM Replacement, RAM: adım 3, 2 resimden 1. HP 2000 - 2D22DX RAM Replacement, RAM: adım 3, 2 resimden 2.
    • After battery removal, the RAM compartment cover is exposed.
    • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
    • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
    FixBot'a Sor
    Yorum Ekle
  4. HP 2000 - 2D22DX RAM Replacement: adım 4, 2 resimden 1. HP 2000 - 2D22DX RAM Replacement: adım 4, 2 resimden 2.
    • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
    • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
    FixBot'a Sor
    Yorum Ekle
  5. HP 2000 - 2D22DX RAM Replacement: adım 5, 3 resimden 1. HP 2000 - 2D22DX RAM Replacement: adım 5, 3 resimden 2. HP 2000 - 2D22DX RAM Replacement: adım 5, 3 resimden 3.
    • Move the black plastic film to the side to locate the RAM slots.
    • Locate the metal clips holding the RAM card in place.
    • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
    FixBot'a Sor
    Yorum Ekle
  6. HP 2000 - 2D22DX RAM Replacement: adım 6, 1 resimden 1.
    • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
    • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Conor Most
2.778 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G40
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 62
Her zaman: 4,348
