Giriş
Directions for the removal and replacement of the RAM module in a HP 2000 - 2D22DX laptop computer. When adding more RAM, always replace the existing modules to ensure compatibility between modules.
Neye ihtiyacın var
Flip the device over and locate the battery compartment.
Slide the battery release latch to the left until the battery is detached from its slot.
A distinguishable pop will be heard when the battery is fully released.
After battery removal, the RAM compartment cover is exposed.
Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
7 farklı kişi bu kılavuzu tamamladı.
