Ana içeriğe geç
HP 2000 - 2D22DX Wireless Card Replacement
Neye ihtiyacın var
  1. HP 2000 - 2D22DX Wireless Card Replacement, Battery: adım 1, 2 resimden 1. HP 2000 - 2D22DX Wireless Card Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Wireless Card Replacement: adım 2, 2 resimden 1. HP 2000 - 2D22DX Wireless Card Replacement: adım 2, 2 resimden 2.
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 1. HP 2000 - 2D22DX Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 2.
    • Locate the RAM compartment cover below the battery compartment.
    • Locate the Phillips head screw securing RAM compartment to plastic chassis.
    • Loosen screw that is securing the RAM compartment with #00 Phillips head screwdriver.
    • Screw is permanently attached to the RAM compartment cover. Do not try to remove completely.
  4. HP 2000 - 2D22DX Wireless Card Replacement: adım 4, 2 resimden 1. HP 2000 - 2D22DX Wireless Card Replacement: adım 4, 2 resimden 2.
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Wireless Card Replacement: adım 5, 1 resimden 1.
    • Locate the wireless module next to the RAM slots.
  6. HP 2000 - 2D22DX Wireless Card Replacement: adım 6, 3 resimden 1. HP 2000 - 2D22DX Wireless Card Replacement: adım 6, 3 resimden 2. HP 2000 - 2D22DX Wireless Card Replacement: adım 6, 3 resimden 3.
    • Locate the gold connecting wire attached to the wireless module. It is labeled with a small sticker that has a circled number one.
    • Using a plastic spudger, disconnect the gold-end of the connecting wire from the wireless module.
    • Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the gold wire and its respective port on the wireless module. Both are very fragile and can be easily ruined.
  7. HP 2000 - 2D22DX Wireless Card Replacement: adım 7, 3 resimden 1. HP 2000 - 2D22DX Wireless Card Replacement: adım 7, 3 resimden 2. HP 2000 - 2D22DX Wireless Card Replacement: adım 7, 3 resimden 3.
    • Locate the small Phillips head screw in the top right corner of the wireless module.
    • Using a #00 Phillips head screwdriver, remove the screw and set aside.
    • The wireless module should now pop up from its slot at a 45 degree angle.
  8. HP 2000 - 2D22DX Wireless Card Replacement: adım 8, 1 resimden 1.
    • Slowly slide the wireless module straight out from its slot in the logic board.
    • Maintain the 45 degree angle of the wireless module until all pins are disconnected. Failure to do so may result in breaking the wireless module connecting pins.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Conor Most
2.687 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-40, Maness Spring 2014 Cal Poly, Team 3-40, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G40
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 1,993
