Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. The equipment comes with two modules to install a supervisor card and 6 expansion slots for compatible modules. J8726A Management Module.'
    • The equipment comes with two modules to install a supervisor card and 6 expansion slots for compatible modules.
    • J8726A Management Module.'
    • J8705A Module 20p 10/100/1000 + 4p SFP.
    • 'RESET' and 'CLEAR' buttons used for: 'CLEAR' Erase only the access passwords when pressed for at least 1 second. 'RESET' Restores factory default settings when pressed in a specific pattern.
    • RS232 console port; any baud rate from 2400 to 115200 (the switch automatically detects the speed) 8 data bits, 1 stop bit, no parity and flow control set to None
    • USB port
    • J4858C - HP Gigabit-SX-LC Mini-GBIC
  2. Android Tamir Setleri
    A new screen or battery is one kit away.
    Hemen Alışveriş Yapın
  3. The modules can be removed with the equipment turned on, with the exception of the 'Management Module'. Loosen the screws, the screw contains a spring and once it is loose it will be ejected and will remain in the equipment. To remove the module, pull the handles that are on the bottom of the module.
    • The modules can be removed with the equipment turned on, with the exception of the 'Management Module'.
    • Loosen the screws, the screw contains a spring and once it is loose it will be ejected and will remain in the equipment.
    • To remove the module, pull the handles that are on the bottom of the module.
  4. Do not remove while the equipment is on Following the same procedure above, loosen the screws and pull the levers of the module to remove it. RAM Memory
    • Do not remove while the equipment is on
    • Following the same procedure above, loosen the screws and pull the levers of the module to remove it.
    • RAM Memory
    • Flash card
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Luis Anniel dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Eneider Colina
1.442 İtibar
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 8
Son 30 Gün: 29
Her zaman: 397
