Ana içeriğe geç
HP 7 1800 Battery Replacement
Neye ihtiyacın var
  1. HP 7 1800 Battery Replacement, Remove the back panel: adım 1, 2 resimden 1. HP 7 1800 Battery Replacement, Remove the back panel: adım 1, 2 resimden 2.
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
    FixBot'a Sor
    Yorum Ekle
  2. HP 7 1800 Battery Replacement, Remove the battery: adım 2, 3 resimden 1. HP 7 1800 Battery Replacement, Remove the battery: adım 2, 3 resimden 2. HP 7 1800 Battery Replacement, Remove the battery: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
TMD
792 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G1
4 Üyeler
14 adet Kılavuz yazıldı
2Kılavuz Yorumları
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - Yanıt Paylaş
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 3,863
