Giriş
This guide requires you to take apart nearly the entire tablet to get to the display. Be sure to keep track of the screws.
Neye ihtiyacın var
Carefully insert a Spudger into one of the corners of the tablet.
Slide the Spudger along the edge popping the tabs out along the way.
Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
Remove the following 7 screws:
Six 4.17mm Phillips #00 around the motherboard.
One 2.67mm Phillips #00 next to the front facing camera.
Gently pry the front facing camera plug up and off of the motherboard.
On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
Unscrew the following black screws:
Seven 2.82mm Phillips #00 around the metal casing.
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I have this same tablet but I cannot find a replacement screen. Do you know where I could find one?
I have the same problem
