Ana içeriğe geç
HP 7 1800 Front Facing Camera Replacement
Neye ihtiyacın var
    1. HP 7 1800 Front Facing Camera Replacement, Remove the back panel: adım 1, 2 resimden 1. HP 7 1800 Front Facing Camera Replacement, Remove the back panel: adım 1, 2 resimden 2.
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      FixBot'a Sor
      Yorum Ekle
    2. HP 7 1800 Front Facing Camera Replacement, Remove the battery: adım 2, 3 resimden 1. HP 7 1800 Front Facing Camera Replacement, Remove the battery: adım 2, 3 resimden 2. HP 7 1800 Front Facing Camera Replacement, Remove the battery: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      FixBot'a Sor
      Yorum Ekle
    1. HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: adım 3, 2 resimden 1. HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: adım 3, 2 resimden 2.
      • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
      FixBot'a Sor
      Yorum Ekle
    2. HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: adım 4, 2 resimden 1. HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: adım 4, 2 resimden 2.
      • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 silver screws from the logic board: adım 5, 1 resimden 1.
      • Remove the following 7 screws:
      • Six 4.17mm Phillips #00 around the motherboard.
      • One 2.67mm Phillips #00 next to the front facing camera.
      • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
      FixBot'a Sor
      Yorum Ekle
    4. HP 7 1800 Front Facing Camera Replacement, Unplug the front facing camera from the logic board: adım 6, 1 resimden 1.
      • Gently pry the front facing camera plug up and off of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. HP 7 1800 Front Facing Camera Replacement, Remove the logic board: adım 7, 1 resimden 1.
      • Carefully lift the motherboard directly up.
      FixBot'a Sor
      Yorum Ekle
    1. HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: adım 8, 2 resimden 1. HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: adım 8, 2 resimden 2.
      • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
      FixBot'a Sor
      Yorum Ekle
    2. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 black screws on the metal plate: adım 9, 1 resimden 1.
      • Unscrew the following black screws:
      • Seven 2.82mm Phillips #00 around the metal casing.
      FixBot'a Sor
      Yorum Ekle
    3. HP 7 1800 Front Facing Camera Replacement, Remove the metal plate: adım 10, 1 resimden 1.
      • Gently lift the metal plate directly up.
      FixBot'a Sor
      Yorum Ekle
    4. HP 7 1800 Front Facing Camera Replacement, Remove the camera: adım 11, 1 resimden 1.
      • Gently remove the camera from the device with tweezers by lifting it up and out of its square hole.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Trevor Shumate
225 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G1
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 555
