Ana içeriğe geç
HP 7 1800 Motherboard Replacement
Neye ihtiyacın var
  1. HP 7 1800 Motherboard Replacement, Remove the back panel: adım 1, 2 resimden 1. HP 7 1800 Motherboard Replacement, Remove the back panel: adım 1, 2 resimden 2.
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Motherboard Replacement, Remove the battery: adım 2, 3 resimden 1. HP 7 1800 Motherboard Replacement, Remove the battery: adım 2, 3 resimden 2. HP 7 1800 Motherboard Replacement, Remove the battery: adım 2, 3 resimden 3.
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: adım 3, 2 resimden 1. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: adım 3, 2 resimden 2.
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: adım 4, 2 resimden 1. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: adım 4, 2 resimden 2.
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: adım 5, 1 resimden 1.
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: adım 6, 1 resimden 1.
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Motherboard Replacement, Remove the logic board: adım 7, 1 resimden 1.
    • Carefully lift the motherboard directly up.
Sonuç
TMD
765 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G1
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 932
