Ana içeriğe geç
HP 7 1800 Speaker Replacement
Neye ihtiyacın var
  1. HP 7 1800 Speaker Replacement, Remove the back panel: adım 1, 2 resimden 1. HP 7 1800 Speaker Replacement, Remove the back panel: adım 1, 2 resimden 2.
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Speaker Replacement, Remove the battery: adım 2, 3 resimden 1. HP 7 1800 Speaker Replacement, Remove the battery: adım 2, 3 resimden 2. HP 7 1800 Speaker Replacement, Remove the battery: adım 2, 3 resimden 3.
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Speaker Replacement, Desolder the speaker wires: adım 3, 1 resimden 1.
    • Desolder the two leads of the speaker wire that are connected to the motherboard.
  4. HP 7 1800 Speaker Replacement, Remove the speaker: adım 4, 1 resimden 1.
    • Using tweezers, gently pull the speaker off of the metal plate.
    • The speaker is held onto the metal plate with light adhesive. It will require a little force to peel off.
Sonuç
TMD
765 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Brown Winter 2015 USF Tampa, Team 4-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S4G1
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 212
