Ana içeriğe geç
HP 7 PLUS 1301 Front and Back Camera Replacement
Neye ihtiyacın var
  1. HP 7 PLUS 1301 Front and Back Camera Replacement, Front and Back Camera: adım 1, 2 resimden 1. HP 7 PLUS 1301 Front and Back Camera Replacement, Front and Back Camera: adım 1, 2 resimden 2.
    • Make sure the device is off and not plugged in before starting.
    • Using a Torx T5 screwdriver, remove the 3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 2, 2 resimden 1. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 3, 2 resimden 1. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 3, 2 resimden 2.
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 4, 1 resimden 1.
    • Locate the front and rear cameras.
  5. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 5, 2 resimden 1. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 5, 2 resimden 2.
    • Using the opening tool, locate the rectangular gray connector near the camera and gently release its connection.
    • Lift the connector out and away from the board.
    • This will come out very easily so don't use much force.
  6. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 6, 2 resimden 1. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently push the tabs on both sides until the front camera is loose.
    • Using your blunt tweezers, lift the front camera gently away from the board.
  7. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 7, 3 resimden 1. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 7, 3 resimden 2. HP 7 PLUS 1301 Front and Back Camera Replacement: adım 7, 3 resimden 3.
    • Using your angled tweezers, gently pry out the back camera.
    • The camera is held down with tape.
    • Lift the back camera out of its socket and gently pull out both cameras.
Sonuç
Bir başkası bu kılavuzu tamamladı.
ahmed musleh
195 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S20-G6, Lore Winter 2019 UC Davis, Team S20-G6, Lore Winter 2019 üyesi
UCD-LORE-W19S20G6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 147
