Ana içeriğe geç
HP 7 PLUS 1301 Speaker Replacement
Neye ihtiyacın var
  1. HP 7 PLUS 1301 Speaker Replacement, Speaker: adım 1, 2 resimden 1. HP 7 PLUS 1301 Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Make sure the device is off and not plugged in before starting.
    • Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Speaker Replacement: adım 2, 2 resimden 1. HP 7 PLUS 1301 Speaker Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Speaker Replacement: adım 3, 2 resimden 1. HP 7 PLUS 1301 Speaker Replacement: adım 3, 2 resimden 2.
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Speaker Replacement: adım 4, 2 resimden 1. HP 7 PLUS 1301 Speaker Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully remove the speaker connector from the socket.
  5. HP 7 PLUS 1301 Speaker Replacement: adım 5, 3 resimden 1. HP 7 PLUS 1301 Speaker Replacement: adım 5, 3 resimden 2. HP 7 PLUS 1301 Speaker Replacement: adım 5, 3 resimden 3.
    • Insert a spudger in the bottom right of the speaker. It makes the speaker easier to come off.
    • Carefully remove the speaker with your hand.
    • Some force needs to be applied here due to the adhesive on the other side of the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shao-Hung Hsiao
201 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S20-G6, Lore Winter 2019 UC Davis, Team S20-G6, Lore Winter 2019 üyesi
UCD-LORE-W19S20G6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 115
