Ana içeriğe geç
HP 7 Plus 1302 Back Cover Replacement
Neye ihtiyacın var
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: adım 2, 2 resimden 1. HP 7 Plus 1302 Back Cover Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: adım 3, 2 resimden 1. HP 7 Plus 1302 Back Cover Replacement: adım 3, 2 resimden 2.
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
Sonuç
Marquies
245 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Renguette SU 2015 IUPUI, Team 1-2, Renguette SU 2015 üyesi
IUPUI-RENGUETTE-SU15S1G2
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 1,024
