Ana içeriğe geç
HP 7 Plus 1302 Battery Replacement
Neye ihtiyacın var
    1. HP 7 Plus 1302 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
      • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
      • Device should be turned off and unplugged before starting the replacements.
      FixBot'a Sor
      Yorum Ekle
    2. HP 7 Plus 1302 Battery Replacement: adım 2, 2 resimden 1. HP 7 Plus 1302 Battery Replacement: adım 2, 2 resimden 2.
      • Use the plastic opening tool to push in between the front and the back of the tablet.
      • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
      • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
      FixBot'a Sor
      Yorum Ekle
    3. HP 7 Plus 1302 Battery Replacement: adım 3, 2 resimden 1. HP 7 Plus 1302 Battery Replacement: adım 3, 2 resimden 2.
      • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
      • Remove the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. HP 7 Plus 1302 Battery Replacement, Battery: adım 4, 2 resimden 1. HP 7 Plus 1302 Battery Replacement, Battery: adım 4, 2 resimden 2.
      • Push out the battery connector using the spudger.
      • Swing the battery connector clear of the connector socket.
      FixBot'a Sor
      Yorum Ekle
    2. HP 7 Plus 1302 Battery Replacement: adım 5, 1 resimden 1.
      • Lift the battery from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Use new double sided tape to secure the new battery.
Bir başkası bu kılavuzu tamamladı.
Jason
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Renguette SU 2015 IUPUI, Team 1-2, Renguette SU 2015 üyesi
IUPUI-RENGUETTE-SU15S1G2
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 2,094
