Ana içeriğe geç
HP 7 Plus 1302 Power and Volume Button Replacement
Neye ihtiyacın var
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: adım 2, 2 resimden 1. HP 7 Plus 1302 Power and Volume Button Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: adım 3, 2 resimden 1. HP 7 Plus 1302 Power and Volume Button Replacement: adım 3, 2 resimden 2.
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: adım 4, 1 resimden 1.
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: adım 5, 2 resimden 1. HP 7 Plus 1302 Power and Volume Button Replacement: adım 5, 2 resimden 2.
    • Pop out the power and volume buttons with your hands
Sonuç
Shannon Suttles
225 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Baechle Spring 2017 IUPUI, Team 1-4, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G4
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 360
