Ana içeriğe geç
HP 8 1401 Battery Replacement
Neye ihtiyacın var
  1. HP 8 1401 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. HP 8 1401 Battery Replacement: adım 2, 1 resimden 1.
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
    FixBot'a Sor
    Yorum Ekle
  3. HP 8 1401 Battery Replacement: adım 3, 2 resimden 1. HP 8 1401 Battery Replacement: adım 3, 2 resimden 2.
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
    FixBot'a Sor
    Yorum Ekle
  4. HP 8 1401 Battery Replacement, Battery: adım 4, 2 resimden 1. HP 8 1401 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. HP 8 1401 Battery Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
    • Do not use a metal spudger, which may damage/puncture the battery and pose a hazard.
    FixBot'a Sor
    Yorum Ekle
  6. HP 8 1401 Battery Replacement: adım 6, 1 resimden 1.
    • Once the battery is removed the battery and tablet should look like this.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Katie Presz
641 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 1,217
