Ana içeriğe geç
HP 8 1401 Front-Facing Camera Replacement
Neye ihtiyacın var
  1. HP 8 1401 Front-Facing Camera Replacement, Back Panel: adım 1, 1 resimden 1.
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Front-Facing Camera Replacement: adım 2, 1 resimden 1.
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Front-Facing Camera Replacement: adım 3, 2 resimden 1. HP 8 1401 Front-Facing Camera Replacement: adım 3, 2 resimden 2.
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Front-Facing Camera Replacement, Front-Facing Camera: adım 4, 1 resimden 1.
    • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
  5. HP 8 1401 Front-Facing Camera Replacement: adım 5, 2 resimden 1. HP 8 1401 Front-Facing Camera Replacement: adım 5, 2 resimden 2.
    • Lift the front-facing camera out of the tablet.
  6. HP 8 1401 Front-Facing Camera Replacement: adım 6, 1 resimden 1.
    • After the front-facing camera has been removed, the tablet should look like this.
Sonuç
Katie Presz
641 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 140
