Ana içeriğe geç
HP 8 1401 Power/ Volume Button Board Replacement
Neye ihtiyacın var
  1. HP 8 1401 Power/ Volume Button Board Replacement, Back Panel: adım 1, 1 resimden 1.
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Power/ Volume Button Board Replacement: adım 2, 1 resimden 1.
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Power/ Volume Button Board Replacement: adım 3, 2 resimden 1. HP 8 1401 Power/ Volume Button Board Replacement: adım 3, 2 resimden 2.
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Power/ Volume Button Board Replacement, Power/ Volume Button Board: adım 4, 3 resimden 1. HP 8 1401 Power/ Volume Button Board Replacement, Power/ Volume Button Board: adım 4, 3 resimden 2. HP 8 1401 Power/ Volume Button Board Replacement, Power/ Volume Button Board: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the power/ volume button board from the control board by pulling the ribbon cable out of the white connector. You can use tweezers or your fingers.
  5. HP 8 1401 Power/ Volume Button Board Replacement: adım 5, 1 resimden 1.
    • After removing the power/ volume button board, it should look like this.
Sonuç
Katie Presz
641 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 246
