Ana içeriğe geç
HP 8 1401 Rear-Facing Camera Replacement
Neye ihtiyacın var
    1. HP 8 1401 Rear-Facing Camera Replacement, Back Panel: adım 1, 1 resimden 1.
      • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. HP 8 1401 Rear-Facing Camera Replacement: adım 2, 1 resimden 1.
      • Insert the tip of a plastic opening tool in the seam between the front and back panels.
      FixBot'a Sor
      Yorum Ekle
    3. HP 8 1401 Rear-Facing Camera Replacement: adım 3, 2 resimden 1. HP 8 1401 Rear-Facing Camera Replacement: adım 3, 2 resimden 2.
      • Slide the plastic opening tool around all edges of the device until the back panel detaches.
      • Lift off the back panel.
      FixBot'a Sor
      Yorum Ekle
    1. HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: adım 4, 2 resimden 1. HP 8 1401 Rear-Facing Camera Replacement, Rear-Facing Camera: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
      • Lift the rear-facing camera out of its compartment using the tweezers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Katie Presz
641 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 314
