Giriş
This guide will help you if your rear-facing camera is cracked or damaged. You may need to pull a little bit to remove the camera, it is well secured in the tablet.
Neye ihtiyacın var
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
Lift the rear-facing camera out of its compartment using the tweezers.
