Ana içeriğe geç
HP Beats Special Edition 15-p390nr Keyboard Replacement
Neye ihtiyacın var
  1. HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 2, 2 resimden 1. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 2, 2 resimden 2.
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 3, 2 resimden 1. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 3, 2 resimden 2.
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 4, 2 resimden 1. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 4, 2 resimden 2.
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 5, 2 resimden 1. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 5, 2 resimden 2.
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 6, 2 resimden 1. HP Beats Special Edition 15-p390nr Keyboard Replacement: adım 6, 2 resimden 2.
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Can you add if we can take trackpad off the keyboard
Paul Schupbach - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 2,774
