Ana içeriğe geç
HP Beats Special Edition 15-p390nr WiFi Card Replacement
Neye ihtiyacın var
  1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: adım 1, 2 resimden 1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: adım 1, 2 resimden 2.
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 2, 2 resimden 1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 2, 2 resimden 2.
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 3, 2 resimden 1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 3, 2 resimden 2.
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 4, 2 resimden 1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 4, 2 resimden 2.
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 5, 2 resimden 1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 5, 2 resimden 2.
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 6, 2 resimden 1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 6, 2 resimden 2.
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, WiFi Card: adım 7, 1 resimden 1.
    • Once the keyboard panel is removed you will need to locate the WiFi card
  8. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 8, 1 resimden 1.
    • Remove two screws using the Phillips #0 screwdriver.
  9. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 9, 1 resimden 1.
    • Remove wire connected to the back of the card by pulling it straight up.
  10. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: adım 10, 1 resimden 1.
    • Pull card away from you to remove it from the motherboard.
    • Refrain from wiggling or moving the card around, while connected to the motherboard, to prevent damage to connector pins.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,105
