Ana içeriğe geç
HP Chromebook 14-x013dx Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook  14-x013dx Battery Replacement, Keyboard, Touchpad: adım 1, 2 resimden 1. HP Chromebook  14-x013dx Battery Replacement, Keyboard, Touchpad: adım 1, 2 resimden 2.
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
    FixBot'a Sor
  2. HP Chromebook  14-x013dx Battery Replacement: adım 2, 1 resimden 1.
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
    FixBot'a Sor
  3. HP Chromebook  14-x013dx Battery Replacement: adım 3, 2 resimden 1. HP Chromebook  14-x013dx Battery Replacement: adım 3, 2 resimden 2.
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
    FixBot'a Sor
  4. HP Chromebook  14-x013dx Battery Replacement: adım 4, 2 resimden 1. HP Chromebook  14-x013dx Battery Replacement: adım 4, 2 resimden 2.
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
    FixBot'a Sor
  5. HP Chromebook  14-x013dx Battery Replacement: adım 5, 3 resimden 1. HP Chromebook  14-x013dx Battery Replacement: adım 5, 3 resimden 2. HP Chromebook  14-x013dx Battery Replacement: adım 5, 3 resimden 3.
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
    FixBot'a Sor
  6. HP Chromebook  14-x013dx Battery Replacement, Battery: adım 6, 2 resimden 1. HP Chromebook  14-x013dx Battery Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
    FixBot'a Sor
  7. HP Chromebook  14-x013dx Battery Replacement: adım 7, 2 resimden 1. HP Chromebook  14-x013dx Battery Replacement: adım 7, 2 resimden 2.
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
    FixBot'a Sor
  8. HP Chromebook  14-x013dx Battery Replacement: adım 8, 2 resimden 1. HP Chromebook  14-x013dx Battery Replacement: adım 8, 2 resimden 2.
    • Unhook the battery's power connector from the motherboard.
    FixBot'a Sor
  9. HP Chromebook  14-x013dx Battery Replacement: adım 9, 1 resimden 1.
    • Lift the battery out of the laptop case.
    FixBot'a Sor
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
NHerbert
602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G6
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 55
Her zaman: 3,287
