Ana içeriğe geç
HP Chromebook 11 G3 Keyboard Mount Replacement
Neye ihtiyacın var
  1. HP Chromebook 11 G3 Keyboard Mount Replacement, Keyboard Mount: adım 1, 2 resimden 1. HP Chromebook 11 G3 Keyboard Mount Replacement, Keyboard Mount: adım 1, 2 resimden 2.
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Keyboard Mount Replacement: adım 2, 2 resimden 1. HP Chromebook 11 G3 Keyboard Mount Replacement: adım 2, 2 resimden 2.
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Keyboard Mount Replacement: adım 3, 1 resimden 1.
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Keyboard Mount Replacement: adım 4, 3 resimden 1. HP Chromebook 11 G3 Keyboard Mount Replacement: adım 4, 3 resimden 2. HP Chromebook 11 G3 Keyboard Mount Replacement: adım 4, 3 resimden 3.
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Keyboard Mount Replacement: adım 5, 1 resimden 1.
    • Lift the keyboard mount out of the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Rahul Goyal
1.369 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G3, Livingston Spring 2017 Cal Poly, Team S23-G3, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 349
