Ana içeriğe geç
HP Chromebook 11 G4 Keyboard Replacement
Neye ihtiyacın var
    1. HP Chromebook 11 G4 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • Position the closed Chromebook with the rubber pads are facing up.
      FixBot'a Sor
      Yorum Ekle
    2. HP Chromebook 11 G4 Keyboard Replacement: adım 2, 2 resimden 1. HP Chromebook 11 G4 Keyboard Replacement: adım 2, 2 resimden 2.
      • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
      • Pry off the rubber pads to reveal a screw under each pad.
      • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
      FixBot'a Sor
      Yorum Ekle
    3. HP Chromebook 11 G4 Keyboard Replacement: adım 3, 2 resimden 1. HP Chromebook 11 G4 Keyboard Replacement: adım 3, 2 resimden 2.
      • Remove the eleven 6mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    4. HP Chromebook 11 G4 Keyboard Replacement: adım 4, 1 resimden 1.
      • Flip over the Chromebook and open it.
      FixBot'a Sor
      Yorum Ekle
    5. HP Chromebook 11 G4 Keyboard Replacement: adım 5, 2 resimden 1. HP Chromebook 11 G4 Keyboard Replacement: adım 5, 2 resimden 2.
      • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
      • Slide the spudger along the gap, applying downward pressure to separate the two components.
      • You should hear popping sounds as you slide the spudger along the edge.
      • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
      FixBot'a Sor
      Yorum Ekle
    6. HP Chromebook 11 G4 Keyboard Replacement: adım 6, 1 resimden 1.
      • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
      FixBot'a Sor
      Yorum Ekle
    7. HP Chromebook 11 G4 Keyboard Replacement: adım 7, 3 resimden 1. HP Chromebook 11 G4 Keyboard Replacement: adım 7, 3 resimden 2. HP Chromebook 11 G4 Keyboard Replacement: adım 7, 3 resimden 3.
      • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
      • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
      FixBot'a Sor
      Yorum Ekle
    8. HP Chromebook 11 G4 Keyboard Replacement: adım 8, 1 resimden 1.
      • Remove the keyboard assembly by lifting it off the laptop base.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jair Herrera
694 İtibar
4 adet Kılavuz yazıldı
3Kılavuz Yorumları
How do you remove the keyboard from the assembly though? And I wish there was a mention of the fact that the heat sink is attached to the keyboard assembly.
Kyle B - Yanıt Paylaş
Same question as the person above. I need to remove the keyboard from the assembly.
Stephen Mason - Yanıt Paylaş
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
Nacho Biniz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 10,131
