Giriş
This guide will walk you through the replacement process of a defective or broken keyboard on your HP Chromebook 11 G4. Removing the keyboard is also the basic step to accessing all of the other internal components.
Neye ihtiyacın var
Remove the eleven 6mm Phillips #1 screws.
really good instructions by the way you should probably sponsor mr smedbergs kalsonger
Lift the bottom of the keyboard assembly to reveal the internal components of the device.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Same question as the person above. I need to remove the keyboard from the assembly.
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
