Ana içeriğe geç
HP Chromebook 11 G4 LCD Replacement
Neye ihtiyacın var
  1. HP Chromebook 11 G4 LCD Replacement, LCD: adım 1, 3 resimden 1. HP Chromebook 11 G4 LCD Replacement, LCD: adım 1, 3 resimden 2. HP Chromebook 11 G4 LCD Replacement, LCD: adım 1, 3 resimden 3.
    • Open the laptop.
    • With the plastic spudger or your fingers, gently peel off the two thin adhesive layers at the left and right bottom edges of the screen.
    • Do not pry up the plastic bezel (monitor frame), just the adhesive layer.
    • If the adhesive layer isn't coming off, use a metal spudger.
  2. HP Chromebook 11 G4 LCD Replacement: adım 2, 2 resimden 1. HP Chromebook 11 G4 LCD Replacement: adım 2, 2 resimden 2.
    • Remove the two 3 mm Phillips #00 screws located underneath the adhesive layers that were removed in the previous step
  3. HP Chromebook 11 G4 LCD Replacement: adım 3, 3 resimden 1. HP Chromebook 11 G4 LCD Replacement: adım 3, 3 resimden 2. HP Chromebook 11 G4 LCD Replacement: adım 3, 3 resimden 3.
    • Gently pry up the plastic bezel with the small, narrow end of the metal spudger.
    • Insert the long, flat end of the metal spudger into the gap.
    • Slide the metal spudger along the edge to disconnect the bezel from the laptop
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, it's okay to use more force.
  4. HP Chromebook 11 G4 LCD Replacement: adım 4, 2 resimden 1. HP Chromebook 11 G4 LCD Replacement: adım 4, 2 resimden 2.
    • Tilt the laptop screen as far back as possible
    • Hold the bezel with both hands, then pull the bezel towards you to disconnect the bottom edge of the bezel from the laptop.
    • You may have to use extra force for this step
  5. HP Chromebook 11 G4 LCD Replacement: adım 5, 3 resimden 1. HP Chromebook 11 G4 LCD Replacement: adım 5, 3 resimden 2. HP Chromebook 11 G4 LCD Replacement: adım 5, 3 resimden 3.
    • Remove the four silver 4 mm Phillips #0 screws at the bottom of the LCD.
    • Remove the four black 3 mm Phillips #00 screws along the perimeter of the LCD.
  6. HP Chromebook 11 G4 LCD Replacement: adım 6, 2 resimden 1. HP Chromebook 11 G4 LCD Replacement: adım 6, 2 resimden 2.
    • Lift the LCD off its mount and gently lay it facedown on the keyboard.
  7. HP Chromebook 11 G4 LCD Replacement: adım 7, 3 resimden 1. HP Chromebook 11 G4 LCD Replacement: adım 7, 3 resimden 2. HP Chromebook 11 G4 LCD Replacement: adım 7, 3 resimden 3.
    • Peel off the clear sticker covering the display cable at the base of the LCD.
    • Gently pull the display cable from the connector.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Jonah Silva
794 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G5, Livingston Spring 2017 Cal Poly, Team S23-G5, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G5
3 Üyeler
6 adet Kılavuz yazıldı
3 Yorum
Thanks for the great guidance. Easy as pie!
lcowsert - Yanıt
i need to replace the top cover of this Laptop HP Chromebook 11-2201NA Can you help
grahamcoles - Yanıt
I did it! Thank you for terrific instructions.
Krenee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 7,687
