Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will walk you through how to replace the SD card reader on the HP Chromebook 11 G4. Once you remove the keyboard, the SD card reader is a cinch to replace.
  1. Position the closed Chromebook with the rubber pads are facing up.
    • Position the closed Chromebook with the rubber pads are facing up.
  2. Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners. Pry off the rubber pads to reveal a screw under each pad.
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. Remove the eleven 6mm Phillips #1 screws. Remove the eleven 6mm Phillips #1 screws.
    • Remove the eleven 6mm Phillips #1 screws.
  4. Flip over the Chromebook and open it.
    • Flip over the Chromebook and open it.
  5. Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body. Slide the spudger along the gap, applying downward pressure to separate the two components.
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. Lift the bottom of the keyboard assembly to reveal the internal components of the device.
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard. Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets. Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. Remove the keyboard assembly by lifting it off the laptop base.
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. Flip up the flap on the ZIP connector with your finger. Gently pull out the ribbon cable. Gently pull out the ribbon cable.
    • Flip up the flap on the ZIP connector with your finger.
    • Gently pull out the ribbon cable.
  10. Remove the two 4 mm Phillips #1 screws. Remove the two 4 mm Phillips #1 screws.
    • Remove the two 4 mm Phillips #1 screws.
  11. Lift the ribbon cable back and out of the way. Pull out the SD card reader.
    • Lift the ribbon cable back and out of the way.
    • Pull out the SD card reader.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jair Herrera
682 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S16G5
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 476
