Ana içeriğe geç
HP Chromebook 11 G5 DC Charging Port Replacement
Neye ihtiyacın var
  1. HP Chromebook 11 G5 DC Charging Port Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 DC Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 DC Charging Port Replacement: adım 3, 1 resimden 1.
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 DC Charging Port Replacement: adım 4, 1 resimden 1.
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 DC Charging Port Replacement: adım 5, 1 resimden 1.
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 DC Charging Port Replacement: adım 6, 1 resimden 1.
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 DC Charging Port Replacement: adım 7, 1 resimden 1.
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 DC Charging Port Replacement: adım 8, 1 resimden 1.
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 DC Charging Port Replacement, DC Charging Port: adım 9, 1 resimden 1.
    • Disconnect the charging port cable from the motherboard using your finger or a spudger and gently pull it off.
  10. HP Chromebook 11 G5 DC Charging Port Replacement: adım 10, 1 resimden 1.
    • Remove the two screws from the hinge of the device using a Phillips #00 screwdriver.
    • Carefully lift the hinge up.
  11. HP Chromebook 11 G5 DC Charging Port Replacement: adım 11, 1 resimden 1.
    • Carefully lift the charging port cable with the hinge up to remove the DC charging port.
  12. HP Chromebook 11 G5 DC Charging Port Replacement: adım 12, 1 resimden 1.
    • Carefully remove the DC charging port from the base using a spudger.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Salma Zitoun
385 İtibar
2 adet Kılavuz yazıldı
Ekip
2 Yorum
I thought it was going to be a little bit more difficult than it was . I got it done in about 15-20 minutes. Thanks to this.
Maryann Charles - Yanıt
Do you guys sell these replacement DC Ports or know where to find them? (I work for a school, but the students keep breaking things! I need, like, 25 of these… yep, it’s that bad. Even found a literal nest of cockroaches inside one of them. I still have the picture/video of it for the morbidly curious lol.)
Aaron Yamauchi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,278
