Giriş
This is a replacement guide for the HP Chromebook 11 G5 motherboard. The main purpose of the steps below is to show you how to replace the motherboard. The motherboard connects many other essential components necessary to operate the device. Symptoms of a defective motherboard include being unable to power the device while it is plugged in to charge and displaying a distorted image even when connected to an external monitor. If these steps are followed carefully and correctly the motherboard should be easily replaced. Be sure to power off your device before beginning the replacement process.
Neye ihtiyacın var
Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
Remove the 4mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
