Giriş
This guide assists in the replacement of the two internal speaker on an HP Chromebook 11 G6 EE.
Neye ihtiyacın var
Remove the screws from the bottom case.
Two M2.5x8 PH1 screws.
Six M2.5x6 PH1 screws.
Use a plastic opening pick to release the clips that secure the keyboard.
Lift up the keyboard part way, being careful to not put stress on the keyboard and touchpad ribbon cables.
Disconnect the keyboard ZIF connector
Lift up the plastic guard covering the three PH0 M2x2 screws and remove them.
Lift the touchpad out and place into new keyboard.
Use a Phillips #1 screwdriver to remove the two 7 mm screws from both sides of each speaker unit.
Lift the speakers from the laptop frame.
To reassemble your device, follow these instructions in reverse order. Taking the battery out is optional but we have included it as a reference.
Bir başkası bu kılavuzu tamamladı.
