Giriş
This guide assists in the replacement of the Wi-Fi card in an HP Chromebook 11 G6 EE.
Neye ihtiyacın var
Remove the screws from the bottom case.
Two M2.5x8 PH1 screws.
Six M2.5x6 PH1 screws.
Use a plastic opening pick to release the clips that secure the keyboard.
Lift up the keyboard part way, being careful to not put stress on the keyboard and touchpad ribbon cables.
Disconnect the keyboard ZIF connector
Lift up the plastic guard covering the three PH0 M2x2 screws and remove them.
Lift the touchpad out and place into new keyboard.
Use a Phillips #1 screwdriver to unscrew and remove the single screw that secures the Wi-Fi card.
Bir başkası bu kılavuzu tamamladı.
