Ana içeriğe geç
HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement
Neye ihtiyacın var
  1. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement, Keyboard & Touchpad Assembly: adım 1, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: adım 2, 2 resimden 1. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: adım 2, 2 resimden 2.
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: adım 3, 3 resimden 1. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: adım 3, 3 resimden 2. HP Chromebook 11 G8 EE Keyboard & Touchpad Assembly Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
Sonuç
Julia Latura
328 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G2
5 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 670
