Giriş
If you are experiencing poor audio quality, first check the device's troubleshooting page. Then if you determine that the speaker's malfunction is a problem with the hardware, this guide is for you. A guide on how to replace your HP Chromebook 11 G8 EE's speakers. Before beginning this process make sure to power off your device and remove disconnect it from its charger.
Neye ihtiyacın var
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Peel back the film over the speaker's motherboard connector.
Disconnect the speaker cable from the connector on the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
