Giriş
This guide will show you how to replace the HP Chromebook 11A G8 EE's Wi-Fi card. The Wi-Fi card is built into the computer allowing your laptop to connect to wireless internet. When your device is unable to connect to wireless internet, it means the Wi-Fi card of the device may need to be replaced.
Neye ihtiyacın var
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Use tweezers to unplug the battery connector from the motherboard.
Bir başkası bu kılavuzu tamamladı.
