Ana içeriğe geç
HP Chromebook 11-2210nr Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook 11-2210nr Battery Replacement, Battery: adım 1, 2 resimden 1. HP Chromebook 11-2210nr Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Position your closed laptop face down to remove the 9 visible 6 mm screws using a Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Battery Replacement: adım 2, 3 resimden 1. HP Chromebook 11-2210nr Battery Replacement: adım 2, 3 resimden 2. HP Chromebook 11-2210nr Battery Replacement: adım 2, 3 resimden 3.
    • Use a metal spudger to remove the two bottom rubber pads located closer to the hinge of the laptop.
    • Remove the two additional 6 mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The other two bottom rubber pads do not have screws beneath them.
  3. HP Chromebook 11-2210nr Battery Replacement: adım 3, 3 resimden 1. HP Chromebook 11-2210nr Battery Replacement: adım 3, 3 resimden 2. HP Chromebook 11-2210nr Battery Replacement: adım 3, 3 resimden 3.
    • Turn the Laptop over, and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
    • Be careful when using the metal spudger as it could cause damage to the internals of the device. Don't push the spudger too deeply into the seam.
  4. HP Chromebook 11-2210nr Battery Replacement: adım 4, 3 resimden 1. HP Chromebook 11-2210nr Battery Replacement: adım 4, 3 resimden 2. HP Chromebook 11-2210nr Battery Replacement: adım 4, 3 resimden 3.
    • Carefully lift the keyboard up and gently place it towards you until the two ribbon wires become visible and place the keyboard down.
    • Locate where the two ribbon wires are being held in place by two locks.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Battery Replacement: adım 5, 3 resimden 1. HP Chromebook 11-2210nr Battery Replacement: adım 5, 3 resimden 2. HP Chromebook 11-2210nr Battery Replacement: adım 5, 3 resimden 3.
    • Using the nylon spudger, push the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is important to use the nylon spudger for this step to avoid any metal on metal circuit damage.
    • This step completely disconnects the keyboard to allow safe removal.
  6. HP Chromebook 11-2210nr Battery Replacement: adım 6, 2 resimden 1. HP Chromebook 11-2210nr Battery Replacement: adım 6, 2 resimden 2.
    • Remove the six 4 mm screws holding the battery in place with a Phillips #1 screwdriver.
  7. HP Chromebook 11-2210nr Battery Replacement: adım 7, 3 resimden 1. HP Chromebook 11-2210nr Battery Replacement: adım 7, 3 resimden 2. HP Chromebook 11-2210nr Battery Replacement: adım 7, 3 resimden 3.
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  8. HP Chromebook 11-2210nr Battery Replacement: adım 8, 3 resimden 1. HP Chromebook 11-2210nr Battery Replacement: adım 8, 3 resimden 2. HP Chromebook 11-2210nr Battery Replacement: adım 8, 3 resimden 3.
    • Carefully lift the battery and remove it from the laptop.
    • The battery may have an adhesive sticker attached to the bottom, if so apply more force when lifting up.
Sonuç
Kimberly Rodriguez
425 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 345
