Ana içeriğe geç
HP Chromebook 11-2210nr LCD Screen Replacement
Neye ihtiyacın var
  1. HP Chromebook 11-2210nr LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove adhesive tabs using fine point tweezers or a metal spudger.
    • These adhesives are typically located at the bottom left and right corners of the screen.
  2. HP Chromebook 11-2210nr LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
  3. HP Chromebook 11-2210nr LCD Screen Replacement: adım 3, 2 resimden 1. HP Chromebook 11-2210nr LCD Screen Replacement: adım 3, 2 resimden 2.
    • Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
    • Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
    • Be sure to disconnect the bezel from all the way around the screen before completely removing.
  4. HP Chromebook 11-2210nr LCD Screen Replacement: adım 4, 2 resimden 1. HP Chromebook 11-2210nr LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
  5. HP Chromebook 11-2210nr LCD Screen Replacement: adım 5, 1 resimden 1.
    • After removing all screws, gently lower the LCD screen onto the keyboard.
    • The LCD screen will not be completely disconnected from the laptop just yet.
  6. HP Chromebook 11-2210nr LCD Screen Replacement: adım 6, 2 resimden 1. HP Chromebook 11-2210nr LCD Screen Replacement: adım 6, 2 resimden 2.
    • Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
  7. HP Chromebook 11-2210nr LCD Screen Replacement: adım 7, 2 resimden 1. HP Chromebook 11-2210nr LCD Screen Replacement: adım 7, 2 resimden 2.
    • Remove the display cable by gently sliding out the cable away from the LCD screen.
    • This action disconnects the LCD screen from the rest of the device, allowing it to be completely removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kimberly Rodriguez
425 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 332
