Ana içeriğe geç
HP Chromebook 11-v002dx Keyboard Replacement
Neye ihtiyacın var
  1. HP Chromebook 11-v002dx Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. HP Chromebook 11-v002dx Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Working with your device plugged in may result in electric shock. Be sure to power off your device and unplug it from any power source before proceeding with step one.
    • Place your laptop bottom up on your work space.
    • Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
  2. HP Chromebook 11-v002dx Keyboard Replacement: adım 2, 3 resimden 1. HP Chromebook 11-v002dx Keyboard Replacement: adım 2, 3 resimden 2. HP Chromebook 11-v002dx Keyboard Replacement: adım 2, 3 resimden 3.
    • Using a sharp tool, remove the six adhesives from the bottom of your laptop to expose the screwheads underneath. Two of the pads are small and four are larger.
  3. HP Chromebook 11-v002dx Keyboard Replacement: adım 3, 2 resimden 1. HP Chromebook 11-v002dx Keyboard Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to loosen the keyboard face from the device.
    • Start prying at one end of the laptop and slowly work your way around so as not to break the keyboard.
  4. HP Chromebook 11-v002dx Keyboard Replacement: adım 4, 2 resimden 1. HP Chromebook 11-v002dx Keyboard Replacement: adım 4, 2 resimden 2.
    • Lift the keyboard so that the inner workings of the laptop are exposed.
    • Gently pull each of the two ribbons connecting the keyboard to the device so that neither ribbon is still connected to the device, only to the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Heather Cooper
185 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G1, Banghart Spring 2017 Cal Poly, Team S14-G1, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 701
