Ana içeriğe geç
HP Chromebook 11-v002dx Screen Replacement
Neye ihtiyacın var
  1. HP Chromebook 11-v002dx Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Insert your spudger between the plastic covering and the back of the case.
  2. HP Chromebook 11-v002dx Screen Replacement: adım 2, 1 resimden 1.
    • With the help of your spudger completely remove the plastic cover from the rest of the case.
  3. HP Chromebook 11-v002dx Screen Replacement: adım 3, 1 resimden 1.
    • Your screen will look like this.
  4. HP Chromebook 11-v002dx Screen Replacement: adım 4, 2 resimden 1. HP Chromebook 11-v002dx Screen Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #0 Screwdriver, remove the four 2.5mm screws holding the screen in place.
  5. HP Chromebook 11-v002dx Screen Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the tape covering the wiring and detach the ribbon cable that secures the screen to the motherboard.
    • Use tweezers if you can't reach it with your fingers.
  6. HP Chromebook 11-v002dx Screen Replacement: adım 6, 2 resimden 1. HP Chromebook 11-v002dx Screen Replacement: adım 6, 2 resimden 2.
    • Remove the display and the case.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 153
