Ana içeriğe geç
HP Chromebook 11-v002dx Trackpad Replacement
Neye ihtiyacın var
  1. HP Chromebook 11-v002dx Trackpad Replacement, Keyboard: adım 1, 2 resimden 1. HP Chromebook 11-v002dx Trackpad Replacement, Keyboard: adım 1, 2 resimden 2.
    • Working with your device plugged in may result in electric shock. Be sure to power off your device and unplug it from any power source before proceeding with step one.
    • Place your laptop bottom up on your work space.
    • Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
  2. HP Chromebook 11-v002dx Trackpad Replacement: adım 2, 3 resimden 1. HP Chromebook 11-v002dx Trackpad Replacement: adım 2, 3 resimden 2. HP Chromebook 11-v002dx Trackpad Replacement: adım 2, 3 resimden 3.
    • Using a sharp tool, remove the six adhesives from the bottom of your laptop to expose the screwheads underneath. Two of the pads are small and four are larger.
  3. HP Chromebook 11-v002dx Trackpad Replacement: adım 3, 2 resimden 1. HP Chromebook 11-v002dx Trackpad Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to loosen the keyboard face from the device.
    • Start prying at one end of the laptop and slowly work your way around so as not to break the keyboard.
  4. HP Chromebook 11-v002dx Trackpad Replacement: adım 4, 2 resimden 1. HP Chromebook 11-v002dx Trackpad Replacement: adım 4, 2 resimden 2.
    • Lift the keyboard so that the inner workings of the laptop are exposed.
    • Gently pull each of the two ribbons connecting the keyboard to the device so that neither ribbon is still connected to the device, only to the keyboard.
  5. HP Chromebook 11-v002dx Trackpad Replacement, Trackpad: adım 5, 1 resimden 1.
    • Remove the keyboard and reveal the underside.
  6. HP Chromebook 11-v002dx Trackpad Replacement: adım 6, 2 resimden 1. HP Chromebook 11-v002dx Trackpad Replacement: adım 6, 2 resimden 2.
    • Using the Phillips #0 Screwdriver, remove the four 2.5mm screws on the bottom plate of the trackpad.
  7. HP Chromebook 11-v002dx Trackpad Replacement: adım 7, 2 resimden 1. HP Chromebook 11-v002dx Trackpad Replacement: adım 7, 2 resimden 2.
    • Using the Phillips # 0 Screwdriver, remove the three 2.5mm screws on the top of the trackpad.
  8. HP Chromebook 11-v002dx Trackpad Replacement: adım 8, 1 resimden 1.
    • Gently lift the trackpad out of the casing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 80
