Ana içeriğe geç
HP Chromebook 11-v011dx Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook 11-v011dx Battery  Replacement, Key Board: adım 1, 3 resimden 1. HP Chromebook 11-v011dx Battery  Replacement, Key Board: adım 1, 3 resimden 2. HP Chromebook 11-v011dx Battery  Replacement, Key Board: adım 1, 3 resimden 3.
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
  2. HP Chromebook 11-v011dx Battery  Replacement: adım 2, 2 resimden 1. HP Chromebook 11-v011dx Battery  Replacement: adım 2, 2 resimden 2.
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
  3. HP Chromebook 11-v011dx Battery  Replacement: adım 3, 2 resimden 1. HP Chromebook 11-v011dx Battery  Replacement: adım 3, 2 resimden 2.
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
  4. HP Chromebook 11-v011dx Battery  Replacement: adım 4, 3 resimden 1. HP Chromebook 11-v011dx Battery  Replacement: adım 4, 3 resimden 2. HP Chromebook 11-v011dx Battery  Replacement: adım 4, 3 resimden 3.
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
  5. HP Chromebook 11-v011dx Battery  Replacement: adım 5, 1 resimden 1.
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
  6. HP Chromebook 11-v011dx Battery  Replacement, Battery: adım 6, 2 resimden 1. HP Chromebook 11-v011dx Battery  Replacement, Battery: adım 6, 2 resimden 2.
    • Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
  7. HP Chromebook 11-v011dx Battery  Replacement: adım 7, 1 resimden 1.
    • Make sure to hold the white tab portion of the plug and not the wire itself. If you unplug it by holding the wires, you may rip out the wires.
    • Slowly unplug the wire that connects the battery to the motherboard with your hands.
  8. HP Chromebook 11-v011dx Battery  Replacement: adım 8, 1 resimden 1.
    • There is a thick black wire strip that is going across the battery for a different part of the HP ChromeBook 11-v011dx. Be mindful when removing the motherboard so you do not damage this strip.
    • Remove the battery carefully using your hands.
Sonuç
Kyle DeMello
542 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Julie Fall 2017 UMass Dartmouth, Team S4-G2, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 488
