Ana içeriğe geç
HP Chromebook 11-v011dx Key Board Replacement
Neye ihtiyacın var
  1. HP Chromebook 11-v011dx Key Board  Replacement, Key Board: adım 1, 3 resimden 1. HP Chromebook 11-v011dx Key Board  Replacement, Key Board: adım 1, 3 resimden 2. HP Chromebook 11-v011dx Key Board  Replacement, Key Board: adım 1, 3 resimden 3.
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
    FixBot'a Sor
  2. HP Chromebook 11-v011dx Key Board  Replacement: adım 2, 2 resimden 1. HP Chromebook 11-v011dx Key Board  Replacement: adım 2, 2 resimden 2.
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
    FixBot'a Sor
  3. HP Chromebook 11-v011dx Key Board  Replacement: adım 3, 2 resimden 1. HP Chromebook 11-v011dx Key Board  Replacement: adım 3, 2 resimden 2.
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
    FixBot'a Sor
  4. HP Chromebook 11-v011dx Key Board  Replacement: adım 4, 3 resimden 1. HP Chromebook 11-v011dx Key Board  Replacement: adım 4, 3 resimden 2. HP Chromebook 11-v011dx Key Board  Replacement: adım 4, 3 resimden 3.
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
    FixBot'a Sor
  5. HP Chromebook 11-v011dx Key Board  Replacement: adım 5, 1 resimden 1.
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
    FixBot'a Sor
Sonuç
Kyle DeMello
542 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Julie Fall 2017 UMass Dartmouth, Team S4-G2, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 467
