Ana içeriğe geç
HP Chromebook 11-v011dx Screen Replacement
Neye ihtiyacın var
    1. HP Chromebook 11-v011dx Screen  Replacement, Key Board: adım 1, 3 resimden 1. HP Chromebook 11-v011dx Screen  Replacement, Key Board: adım 1, 3 resimden 2. HP Chromebook 11-v011dx Screen  Replacement, Key Board: adım 1, 3 resimden 3.
      • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
      • Lift up the black rubber cap until it is completely removed.
      • Repeat this until all four of the black rubber caps are removed.
      FixBot'a Sor
      Yorum Ekle
    2. HP Chromebook 11-v011dx Screen  Replacement: adım 2, 2 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 2, 2 resimden 2.
      • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
      • Lift up the small black rubber cap until it is completely off.
      • Repeat this step one more time to remove the other small black rubber cap on the other side.
      FixBot'a Sor
      Yorum Ekle
    3. HP Chromebook 11-v011dx Screen  Replacement: adım 3, 2 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 3, 2 resimden 2.
      • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
      • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. HP Chromebook 11-v011dx Screen  Replacement: adım 4, 3 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 4, 3 resimden 2. HP Chromebook 11-v011dx Screen  Replacement: adım 4, 3 resimden 3.
      • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
      • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
      • Lift the spudger a little in the front of the keyboard until the key board lifts up.
      • With your hands, slowly and carefully lift the key board up.
      FixBot'a Sor
      Yorum Ekle
    5. HP Chromebook 11-v011dx Screen  Replacement: adım 5, 1 resimden 1.
      • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
      • Slowly unplug this wire that connects to the key board.
      FixBot'a Sor
      Yorum Ekle
    1. HP Chromebook 11-v011dx Screen  Replacement, Screen: adım 6, 2 resimden 1. HP Chromebook 11-v011dx Screen  Replacement, Screen: adım 6, 2 resimden 2.
      • Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
      FixBot'a Sor
      Yorum Ekle
    2. HP Chromebook 11-v011dx Screen  Replacement: adım 7, 2 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 7, 2 resimden 2.
      • Remove the wireless card from the motherboard with your own hand.
      FixBot'a Sor
      Yorum Ekle
    3. HP Chromebook 11-v011dx Screen  Replacement: adım 8, 2 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 8, 2 resimden 2.
      • Find the wire that connects the screen to the motherboard.
      • Lift black tab that holds the wire in place.
      • Remove the wire.
      FixBot'a Sor
      Yorum Ekle
    4. HP Chromebook 11-v011dx Screen  Replacement: adım 9, 2 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 9, 2 resimden 2.
      • Find the display cable that connects the screen to the motherboard.
      • Lift black tab that holds the display cable in place.
      • Remove display cable.
      FixBot'a Sor
      Yorum Ekle
    5. HP Chromebook 11-v011dx Screen  Replacement: adım 10, 3 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 10, 3 resimden 2. HP Chromebook 11-v011dx Screen  Replacement: adım 10, 3 resimden 3.
      • Use a Phillips #0 screwdriver to remove the four 1.3mm screws that hold the screen in place.
      • Two screws are on the left of the laptop and two are on the right of the laptop.
      FixBot'a Sor
      Yorum Ekle
    6. HP Chromebook 11-v011dx Screen  Replacement: adım 11, 2 resimden 1. HP Chromebook 11-v011dx Screen  Replacement: adım 11, 2 resimden 2.
      • Be careful when removing the screen so it doesn't get caught on any wires.
      • Remove the screen from the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle DeMello
542 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Julie Fall 2017 UMass Dartmouth, Team S4-G2, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G2
3 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 1,127
